D15 Diesel Series 1 Battery Cables |
jenester
Joined: 11 Mar 2013 Location: SW Virginia Points: 22 |
Topic: D15 Diesel Series 1 Battery CablesPosted: 22 Dec 2025 at 9:03am |
I’m adding the second battery (fender mount) to my D15 Diesel Series 1. What size cables do I need to run? I can’t find any information as far as OE goes so I’m thinking 1/0 just based on length and amperage. Does anyone have any firsthand knowledge they can share?
1961 D15 Diesel
Joined: 11 Sep 2009 Location: illinois Points: 89291 |
Posted: 22 Dec 2025 at 4:47pm |
Stock was probably 2 Gauge... I would agree that the 1/0 is a good upgrade and real benifit when its cold outside..
WeisAC2
Posted: 23 Dec 2025 at 10:02am |
Steve @ B&B Custom circuits made one for my D15 diesel. I'm pretty sure it was 2/0 and was 8 foot in length to get back to the accessory battery over the axle. Works well and definitely helps having 2 batteries.
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5197 |
Posted: 23 Dec 2025 at 7:07pm |
Bigger can't hurt when it comes to battery cables. They should never feel hot when starting, if so you're either cranking the engine tooo long or the cables are tooo small.
REEDE
Posted: 25 Dec 2025 at 11:02am |
use 1/0 gauge you will be much happier, may have to get them made.
Calvin Schmidt
Joined: 11 Sep 2009 Location: Ontario Can. Points: 4574 |
Posted: 25 Dec 2025 at 3:15pm |
I make my own with welding cable
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4200 |
Posted: Yesterday at 5:24am |
Just made one for D-17-3 out of 2/0 welder cable.
AC720Man
Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5322 |
Posted: 21 hours 12 minutes ago at 9:13pm |
I use 2/0 welding cable as well and crimp the ends with my crimp tool.
