D15 Diesel Series 1 Battery Cables
jenester View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jenester Quote  Post ReplyReply Direct Link To This Post Topic: D15 Diesel Series 1 Battery Cables
    Posted: 22 Dec 2025 at 9:03am
I’m adding the second battery (fender mount) to my D15 Diesel Series 1. What size cables do I need to run? I can’t find any information as far as OE goes so I’m thinking 1/0 just based on length and amperage. Does anyone have any firsthand knowledge they can share?
1961 D15 Diesel
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2025 at 4:47pm
Stock was probably 2 Gauge... I would agree that the 1/0 is a good upgrade and real benifit when its cold outside..
WeisAC2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WeisAC2 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2025 at 10:02am
Steve @ B&B Custom circuits made one for my D15 diesel.  I'm pretty sure it was 2/0 and was 8 foot in length to get back to the accessory battery over the axle.  Works well and definitely helps having 2 batteries.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2025 at 7:07pm
Bigger can't hurt when it comes to battery cables. They should never feel hot when starting, if so you're either cranking the engine tooo long or the cables are tooo small.
REEDE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote REEDE Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 11:02am
use 1/0 gauge you will be much happier, may have to get them made.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 3:15pm
I make my own with welding cable
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 12 hours 57 minutes ago at 5:24am
Just made one for D-17-3 out of 2/0 welder cable.
