D15 diesel engine looks OK?
Alex09(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Topic: D15 diesel engine looks OK?
    Posted: 20 May 2016 at 10:51pm
My hybrid d15 diesel project tractor: I had to take the head off because when I got an exhaust valve unstuck, I must have knocked some rust off the head and I could not turn the engine all the way over anymore. I was surprised at how good I thought it looks. I was expecting to see cracks and sunken sleeves, but it doesn't seem to be the case. I will do some work on the head though. I believe this is the 4cyl version of the D19 diesel engine? Looking for opinions from the guys that deal with these diesels if this looks ok?
www.awtractor.com
A&W TRACTOR 920-598-1287
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2016 at 9:46am
That engine has definitely taken on some water in its past from the pitting on those pistons.  I would at least hone the sleeves and check the bottom end out while you are at it.
