D15/D14 final drive oil spec? |
Post Reply |
ac45dave
Orange Level Access Joined: 23 May 2015 Location: SE(IN) Points: 1336 |
Posted: 15 Mar 2021 at 7:23pm |
I've recently added D14 and D15 to the fleet.Looking through the manuals I've noticed they call for 20w oil in the final drives.What was the reason for going to 20w for the finals in these tractors while D17 and wd45s called for 80w. Also what is the special transmission oil the d15 manual specifies equivalent to today?
Edited by ac45dave - 15 Mar 2021 at 7:26pm |
Orange Level Access Joined: 12 Sep 2009 Points: 20184 |
You can use modern day Universal Transmission/Hydraulic fluid in every single compartment on that tractor except the engine. Power steering, hydraulic system, Power Director clutch, transmission and both final drives.
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 80165 |
Dr is probably right, but i still wonder why UTF in the final drives.. They must have tested and said OK....... 40 years ago a 3/4 ton truck and 90 w gear lube in the transmission and rear end......... I bought a 1989 FORD with a 5 speed ZF transmission ( manual) and it had ATF in it.. That seemed odd to me.. I asked FORD and they said the transmission was "high speed" and the rear end was "low speed"... and slower turning heavier loaded gears needed gear lube.
Modern Day Universal Trans/Hydraulic fluid is plenty good enough for 600 HP Challenger final drives, I'd think it would be just fine for a 40 HP D-15.
ac45dave
Edited by ac45dave - 15 Mar 2021 at 11:28pm |
jaybmiller
Orange Level Access Joined: 12 Sep 2009 Location: Greensville,Ont Points: 22249 |
maybe...since 80w is 'thicker' ,it'd 'stick' to the gears better/longer ? then the son of the guy in charge of supplies got a job at a '20W refinery' ,so daddy rewrote the 'spec' so the son could make some real money ?? I'm waiting for the 'no engine oil' day seeing how they have ZEROW oils..what # is next ??
WF owner
Orange Level Joined: 12 May 2013 Location: Bombay NY Points: 4593 |
They quit making the D-14 in 1960. Like everything else, lubricants have advanced a lot in 60 years.
Do I know for sure why they changed viscosity specs?? Nope. But I can guess. Before 1960 and the John Deere 3010/4010 everyone probably used an 80/90 weight oil in a high tooth pressure/slow speed final drive. When Deere's new tractor needed the hydraulic oil to be the transmission/hydraulic /wet brakes/final drive oil, oil scientists came up with what we call "303" oil that was able to take care of all of these components. I'm sure 80/90 was cheaper to produce, and still was produced, but now a new type of lubricant exists and slowly has taken over what used to be a heavy oils job. Think about it. A final drive on a 600 HP Challenger uses this modern oil without any troubles, why can't a D-14 ?? Remember, the D-14 came from the "CA" and it too had 20W oil in its final drives with no problems.
Hurst
Orange Level Joined: 11 Sep 2009 Location: Midway, Ky Points: 1211 |
Don't forget, comparing automotive engine oil weights to gear oil weights is not a direct cross. 80 weight gear oil is around the same viscosity as an SAE20 motor oil (between SAE20 and SAE30). So the fluid properties of the lubricants are going to be pretty similar as far as viscosity and hydro-dynamic properties. The differences are mainly in the additives, the gear oils generally having a higher extreme pressure additive package and typically pricier to put together. If I had to reverse-engineer it, I would guess the D14 finals were sized there they did not require a lot of EP additives to survive because they were relying more on the oil's fluid film strength to protect the parts and not entering the realm where heavy EP additives are required (enough stress to break the fluid film and have direct metal-metal contact). The larger tractors probably were at danger of this, hence the gear-oil call out. Another thing to watch for is brass bushings can be damaged by certain gear oils due to high amounts of sulfur EP additives. Not sure if that is a concern with the D14.
1979 Allis Chalmers 7000
5800 Hours |
Post Reply | |
