D15 Clutch
powertech84 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote powertech84 Quote  Post ReplyReply Direct Link To This Post Topic: D15 Clutch
    Posted: 19 Mar 2026 at 9:11am
Does anyone recognize this clutch? I removed it from a D15 series 1 last night. It is heavy.  The pieces welded in between the springs are solid steel. I'm just curious if this is something home made and made to fit, or was something that people used for certain applications for some reason.
It's toast, and I'm replacing it with a standard off the shelf clutch.
WeisAC2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WeisAC2 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2026 at 9:43am
Above is the picture of the clutch from my 1961 D15 Diesel Series 1 that was rebuilt by Rick Corder.
TramwayGuy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TramwayGuy Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2026 at 10:33am
They were probably meant to add rotating mass to the flywheel….
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2026 at 10:58am
I have a couple pressure plates like that. Also the lining on the old clutch is between the Old type fiber lining and cerra metallic. I will have less slip than the fiber and it's easier on the flywheel than a button disc.  I have some of those in my NOS parts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2026 at 11:53am
AGCO parts books only shows one pressure plate for gas and diesel. I could see that heavy one being used on the higher compression diesel to smooth it out. Remember, D-14-15's only had a 9 inch clutch and a pretty small diameter (and light-weight) flywheel as compared to a WD-45 with a 10 inch clutch and 50 lbs flywheel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote powertech84 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2026 at 8:40pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote powertech84 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2026 at 8:42pm
I also decided to take a look at the power director since I had it apart. It was a little noisy but was still working. For some reason the tin shield got all chewed up. I really dont know how this happened. The bearings seem tight. The snap rings were all where they needed to be. The drive hubs should not have been able to make contact here, but something happened.
Edited by powertech84 - 19 Mar 2026 at 8:43pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2026 at 9:02pm
Looks like a shade tree mechanic tried to remove snap ring. Does look like a failure internally. If so, there will be parts in bottom of sump housing. JMHO, Tracy
Edited by Tracy Martin TN - 19 Mar 2026 at 9:03pm
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2026 at 8:34am
Inside that bearing retainer sleeve - the one with the metal chute above the shaft, there is supposed to be a spring. The purpose of the spring is to funnel or auger oil to the clutch - there are two - one for the power director and one for a shuttle as in a fork lift. These sometimes wear out and break apart - usually resulting in the damage shown.  70228322 is pn.
Post Options Post Options   Thanks (0) Thanks(0)   Quote powertech84 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2026 at 8:47am
Yes- I finished taking it apart this morning before going in to work and sure enough, that spring disintegrated. I'm heading to the salvage yard tomorrow to try to find some parts. Currently the prices I'm seeing online are a bit high considering the drop in value these D series have had the last couple years.
