D-15 Belt Pull Hydraulic Pump |
hwstem
Joined: 02 May 2013 Location: Milford NJ Points: 98 |
Topic: D-15 Belt Pull Hydraulic PumpPosted: 23 Jun 2023 at 11:00am |
My neighbor wants to add an optimal hydraulic pump for the belt pulley to his D-15 diesel. Are they available if so where at? And what needs to be done to do so?
Thank you in advance! -Wade |
1939, RC Allis, 1941, Farmall A, 2 1938 Silver King R-44's (to make one) 1953? Case SC (parts for sale) -"If you are going to do something, do it right"
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25256 |
Posted: 23 Jun 2023 at 1:57pm |
Pretty sure belt pulley will stop when clutch is pushed in.... If so,depending on application, this could be a bad thing ?? Only way I know to get a true 'live' hydraulic pump, would be off the front of the the crankshaft.
coggonobrien
Joined: 14 Nov 2010 Location: Eastern Iowa Points: 1890 |
Posted: 23 Jun 2023 at 2:10pm |
Posted: 23 Jun 2023 at 3:29pm |
"Optimal" hydraulic pump?? how about "auxiliary" hydraulic pump ?? I know they made one for the D-17 and could have for the D-15 as well. A poor set-up at best. Only worked when your foot was off the clutch pedal. No parts available any more unless by chance you found a salvaged tractor with the optional hydraulic system. The home-made "live" system is by far superior or a front pump from an all-hydraulic loader is too.
rtwfarm
Joined: 26 Feb 2012 Location: nebraska Points: 1349 |
Posted: 23 Jun 2023 at 5:31pm |
Got a d15 d highcrop with side mounted pump. 402-469-1738
Edited by rtwfarm - 23 Jun 2023 at 5:31pm |
Posted: 23 Jun 2023 at 5:40pm |
So, it's more than just the pump, right ?? It has an oil tank on the right platform and some sort of a hydraulic valve stack ?? maybe on the left side beside the seat??
rtwfarm
Posted: 23 Jun 2023 at 5:44pm |
Call for pictures 402-469-1738
rtwfarm
Posted: 23 Jun 2023 at 8:42pm |
Pics sent
MadCow
Joined: 27 Aug 2023 Location: South Dakota Points: 194 |
Posted: 27 Aug 2023 at 1:58pm |
Kit? Parts list? Edited by MadCow - 27 Aug 2023 at 1:59pm |
Posted: 27 Aug 2023 at 3:25pm |
This hydraulic system is a "one-of", utilizing a hydraulic pump from a Northern Hydraulics Catalog, making a pump mounting bracket that attaches to the thermostat housing, adding a second pulley to the crankshaft pulley and finally using a hydraulic console/valve stack from a D-17 IV or 170-175-180-185 tractor. All the hoses and connections were selected to get the installation completed on the D-15 II chassis in March of 2017. The original hydraulic sump is tapped into on the front left side corner for hydraulic oil supply and there is a return filter from a 180-190-200 under the left rear axle area to filter all return oil. The only time any hydraulic oil ever leaves the sump is when a one-way cylinder is extended, so a couple of quarts at the most. When using a 2-way cylinder extending, even less oil leaves the sump. It has performed flawlessly for 6+ years and is pretty neatly installed.
Edited by DrAllis - 27 Aug 2023 at 4:06pm |
Mikez
Posted: 27 Aug 2023 at 4:43pm |
We have a D14 industrial with a pippin loader on it. It had a side pump. I don’t remember being bothered by having to make sure foot clutch was out. The center plate cracked and couldn’t find replacement so we put front pump on it
Edited by Mikez - 27 Aug 2023 at 4:47pm |
Posted: 27 Aug 2023 at 5:08pm |
As far as I know, any D-14/D-15 side pump was dead when the foot clutch pedal was depressed. Only the D-17 IV and One-Seventy's were "live" at that drive location.
Mikez
Posted: 27 Aug 2023 at 5:11pm |
Guess what I meant was don’t remember it being a nuisance. Having shuttle clutch helps though
Mikez
Posted: 27 Aug 2023 at 5:14pm |
Edited by Mikez - 27 Aug 2023 at 5:15pm |
coggonobrien
Posted: 31 Aug 2023 at 11:09am |
Here is the build thread for the d15 live hydraulic conversion. I did all the fab work, Dr did the engineering. Still works beautifully
