D-15 175 engine
loyalorange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote loyalorange Quote  Post ReplyReply Direct Link To This Post Topic: D-15 175 engine
    Posted: 08 Mar 2012 at 4:25pm
Newby here members, I'm looking for he torque sequence for this engine.  A few years (10 or 12), we tore it down, redone the top end and now wondering if the head required a re-torque after so many hours.  Runs fine but have to pull it halfway to Chicago to get it to fire. Injectors were rebuilt at that time also.  Thanks much. Bill
D17countryboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D17countryboy Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2012 at 6:23pm
I don't think that the torque of the head has anything to do with it not wanting to fire up easy expecially being the head job was done so many years ago. Have you tried using starting fluid? I know with my D-17 262 diesel since it was brand new we always have to use starting fluid to get it to start easy otherwise it will just sit there and crank forever before it will fire up and run.
Post Options Post Options   Thanks (0) Thanks(0)   Quote loyalorange Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2012 at 7:46pm
Yes, it has an addiction to either.  Dosen't help much though.
Ian View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2012 at 8:39pm
Not to familiar with how these are timed, by that I mean I don't know if the pump pulley is pressed on or bolted, but slipped timing can cause hard starting.  also air in the fuel supply line.
1980 AC 616
1958 AC D14
1960 AC D14
1987 Cub 1204
1982 Cub 682
1974 Cub 154 Lo-Boy (SOLD)
Hauler: 1998 Dodge Ram2500 Cummins
Post Options Post Options   Thanks (0) Thanks(0)   Quote loyalorange Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2012 at 10:42am
I would still like to know if anyone could share a torque sequence for this engine.  I believe it is usually center bolts and work the way out to ends?  Should I check compression on this and what should it be?
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2012 at 11:17am
No torque sequence. Start in center and work to outside edges and go in stages.
1968 D15D,1962 D19D
Post Options Post Options   Thanks (0) Thanks(0)   Quote loyalorange Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2012 at 12:09pm
Thanks.  Do you know what the compresion should be ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2012 at 12:20pm
I'd like to say it should be up close to 400 but I don't know for sure. I have the adapter to check compression on a 262, just have never done it. In the 40's, my D17D starts hard. It will start without any assistance. Below 40 it takes a whiff (I mean a slight whiff) of ether or a block heater.
Post Options Post Options   Thanks (0) Thanks(0)   Quote loyalorange Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2012 at 12:23pm
Where would you plug the adaptor in?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2012 at 12:30pm
It goes in place of the injector. Should be the same as used on the 262.
D-17_Dave View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2012 at 8:44pm
Sounds like the transfer pump is weak. Transfer pump in the input of the injector pump. If the transfer pump cannot build enough pressure at cranking speed to force fuel into the rotor head of section of the high pressure pump then it will never fire. The pump, timing, and compresion all have serious contributions to these engines.
Yea, I can fix that.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote loyalorange Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2012 at 2:21pm
I think you have it!  That's where we'll start.  Thanks!
This page was generated in 0.039 seconds.
