D14
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Topic: D14
    Posted: 31 Aug 2011 at 10:37am
There is one coming up on auction, the paint is good, wide front end, tires are OK, has a AC trip loader and 5715 hours.
Whats your oppions on them?
What is there to look for do they have comon problems?
Also will they pull a 3-14 plow ok?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2011 at 12:27pm
Can you drive it before the sale? You want to know if it jumps out of gear, usually 2nd or 3rd. They're rated for 3 14's.
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2011 at 12:38pm
Appears to be a 1960.
It has power steering that is a plus!  If it works.
Not sure what the deal is with the power director handle.  Funny looking add-on?
Got decent looking rubber, but look over the rear rims close for corrosion, especially around the valve stem hole.  If they are 26" they can get pricey for new.
Looks nice in the picks and if everything works as it should, I would guess around $2000.
I love my D14.
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2011 at 1:04pm
John the handle you are seeing is the trip handle for the bucket on the loader "I think".
And $2000 is alot of money to spend for me.
Also how would you compare it to a wd45?
Edited by R.W - 31 Aug 2011 at 1:05pm
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2011 at 1:07pm
Power director lever looks to be ok, I think you are looking at the trip lever for the bucket.
there was one here locally that sold for $2600 with out power steering.
If that one is as nice as it looks I would say it would be worth close to $3000
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2011 at 1:32pm
That is a nice D14! The main issue as mentioned is the gear popping out. Otherwise they were good tractors comparing to a WD. Not enough power to compare to -45.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2011 at 2:43pm
Yep, missed that, in the pic it looked to me like they were connected!
If you look close at the closeup pic of the front right, it looks like it could have a second, not so good, coat of paint.  Dupont overhaul?
Doesn't have the hp of the 45 but with the low/high range it can get down and dig!
It really depends on the folks that attend, but I would think it would go for a minimum of 2000.
It doesn't have a 3 point which could dissuade potential buyers.
Where an when is this auction?  :)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2011 at 3:36pm
Check the front support and pivot for WFE.Loader will wear them bad. Tracy Martin
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2011 at 3:41pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2011 at 7:10am
That's the only farm equipment listed.  I have found you get less farm equipment buyers when there is very little equipment.  Just seems that way to me, I may be wrong!
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2011 at 11:37am
I thought they had about the same power of a wd45, don't really want to get anything less that about 45hp.
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2011 at 12:09pm
Series 2 D15 gas had the same HP as a WD45. D14 is only about 35 PTO HP if I remeber correctly
1968 D15D,1962 D19D
HagerAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2011 at 11:07pm
D-14 are great little tractors.  Grandpa bought on new, and now has probably 20,000 hours on it.  We pull 3-14 easy with ours.  In my opinion I would say a D-14 is handier than a WD-45 because they are easy to get on and off and have the power-director.
