D14 wiring
mmorris View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mmorris Quote  Post ReplyReply Direct Link To This Post Topic: D14 wiring
    Posted: 13 Feb 2014 at 7:18pm
I just melted my wiring. Does anyone know where I can find a wiring diagram for a D14 that has been converted to 12V? It has an alternator and a push button starter as well as the usual gauges. Thanks.
matt dill View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote matt dill Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2014 at 7:25pm
How many wire alternator, 6 volt or 12 volt coil?
ALLIS EXPRESS
1957 D14, 1947 C, 1939 B, 1956 WD45, 1989 Kubota b1750
Post Options Post Options   Thanks (0) Thanks(0)   Quote mmorris Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2014 at 8:04pm
Sorry, not familiar with mechanical terminology. How can I tell?
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2014 at 11:15pm
Hey MMorris, I have a dwg. I downloaded with a very simple 6 to 12 volt conversion with Key/ solenoid start. It has Napa part numbers if you want to use napa parts. It uses the universal 4 position ignition switch, an amp gauge and a toggle switch for the lights.
I plan to use this version on my D14, as I like the negative ground system instead of the allis positive ground. Don't ask me why.
If you're interested, I will try to scan it to my hard drive and post it or email to you. Joe r
Post Options Post Options   Thanks (0) Thanks(0)   Quote mmorris Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2014 at 11:20pm
Thanks, desertjoe! My system is negative ground.
I'm in no hurry, but that diagram would be appreciated.
Monte
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2014 at 8:09pm
Hey Monte, PM me your email as I have not been able to get my scanner to talk to the desktop. I can scan to hard drive but cannot even copy/paste to this site for some reason,,,,? I CAN email the doc but nothing else.
Any computer "Gurus" care to offer suggestions? Thanks Joe r
MClem View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MClem Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2018 at 5:09pm
Is there any way I can get a copy of the dwg from the wireing for for the d14 6to 12 volte I'm having problems. Thanks in advance
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2018 at 6:08pm
There are hundreds of drawings if you search google. It depends on what you have for a generator or alternator whether you need a voltage regulator, and what you use for a coil.
 6 volt coil would need a ballast resistor, 12 volt 3 ohm coil wouldn't.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2018 at 9:14pm
Owner's manual has the complete wiring diagram, except for the alternator...
This page was generated in 0.268 seconds.
