D14 Transport valve cap
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Topic: D14 Transport valve cap
    Posted: 30 Aug 2011 at 10:22pm
Hi Everyone,
I am looking for 2 of these caps that you see in the picture here.  The tractors currently have remote outlets on them and I want to replace them with original caps.
Please let me know what you have.  Thanks!
Burgie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burgie Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2011 at 5:44am
I think that is a regular pipe cap.
"Burgie"
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2011 at 5:48am
You should be able to find those at your local hardware store or from a plumber.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2011 at 6:07am
Just be sure they're good for HIGH pressure ! A-C pumps out 3500#.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2011 at 6:47am
The photo above shows what appear to be standard schedule 40 galvanized pipe fittings. Although not rated to the pressure in an older Allis tractor, they will hold up years under normal conditions. I have schedule 40 fittings on my WD45 and they held up when the bypass didn't work and the traction booster gauge was blown (over 5000 PSI).
This page was generated in 0.432 seconds.
