D14, tiller? |
Post Reply |
Wdtractorman
Orange Level Joined: 24 Sep 2013 Location: Kentucky Points: 975 |
Posted: 18 Dec 2018 at 3:19pm |
Would a d14 run slow enough to use a 3pt tiller very well? I'm kinda wanting a tiller and will need a tractor with a low range that can creep along to fix gardens. Thanks Wil
GregLawlerMinn
Orange Level Joined: 11 Sep 2009 Location: Lawler, Mn Points: 1226 |
I run a 6' tiller behind my D14; 1st Low for 1st few times, then 2nd-low or 2nd high for finishing. Works for me.
Currently have: 1 D14 and a D15S2. With new owners: 2Bs,9CAs,1WD,2 D12s,5D14s,3D15S2s, 2D17SIVs,D17D,1D19D;1 Unstyled WC |
john(MI)
Orange Level Joined: 12 Sep 2009 Location: SE MI Points: 9263 |
I guess it depends on the dirt! It should work fine but you may have to feather the big stick on occasion.
wfmurray
Orange Level Joined: 13 Sep 2009 Location: Bostic NC Points: 1225 |
The smaller the rear tire the slower the speed.Might drop air presure a little.
Ranse
Orange Level Joined: 11 Mar 2016 Location: Tennessee Points: 773 |
I use a tiller behind my D10. In 1st gear with the throttle at three quarters, it runs across the garden pretty darn fast for me. It does do a pretty good job though. However, I can put the same tiller on my 2-60 White, which has a low range, and I can go much slower and do a little smoother more thorough job.
Wdtractorman
What my concern is i fix 3 gardens for Neighbors plus mine. The last few years we have been having very wet Springs and it tough sometimes to get them all plowed and disked between rains. I was thinking if I had a tiller it would be more of a one trip deal, I could run over each garden maybe twice with a tiller and do them all one day and be done. If I'm understanding how one of those 3pt tiller work. I'm thinking you would need a go pretty slow on the first trip over anyway to make a nice looking seed bed. That being said iv never used one
I looked up the ground speed of a 14 on tractor data and it said 1.5mph, witch it about the same as most tractors with a high/low transmission. That being said I'm not sure what rpm that 1.5 mph is. I'm assuming it at a low rpm bc, but I don't know myself. |
Ranse
The slower you go the better it's going to do of coarse. But, you should be alright. I usually don't plow my gardens. I usually till twice, and I go a different direction the second time. A D14 in low one may be slower than a D10, which doesn't have a high/low. I don't know, it's been a long time since I've drove a D series with two speed hand clutch.
jaybmiller
Orange Level Access Joined: 12 Sep 2009 Location: Greensville,Ont Points: 21451 |
I uses a 5' tiller behind 'Troy'. Wife's garden has a lot of humus or tilthe. I don't even bother with plow anymore, sold the discs, cultivators are on a trailer....I just till. 1st pass kinda rough, 2nd, 3rd make it 'seed bed ready. I go W-E then E-W then W-E, seems to 'fluff' up the soil better.Also I let it 'air dry' a tad( I'm not in a hurry ) if it's wet-dampish. 1st pass I need to 'feather' the PD, 2nd-3rd...just run tad over idle, letting the tiller do what it's supposed to. I do need to adjust the tiller more right,get it behind the right tire..yeah 'on the list'.....maybe next Spring... Have to say the tiller was the BEST money I spent ! Got rid of the Ford LGT125 with 3' tiller(wore out), and a walkbehind too. It cost me 1500 Canucks, s in near perfect condition and I know will outlive me. It does 'find' a rock and snaps a shearpin...not a big deal thugh. Jay
Gary Burnett
Orange Level Access Joined: 11 Sep 2009 Location: Virginia Points: 2851 |
I've run a tiller with a D15 it was 'OK' but my MF 220 compact with multiple very slow gears is a lot better
TimCNY
Orange Level Joined: 15 Apr 2014 Location: Upstate NY Points: 1551 |
jaybmiller, what brand tiller do you use? For that matter, I figure maybe this is a question for another thread, I don't mean to get off track.
Post Reply | |
