D14 starter for a CA?
J&J View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote J&J Quote  Post ReplyReply Direct Link To This Post Topic: D14 starter for a CA?
    Posted: 13 hours 2 minutes ago at 10:19pm
Is a 12v D 14 starter mechanically compatible with a CA. I'd like to change it out for the purpose of having a 12v starter and the use of a solenoid. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 12 hours 19 minutes ago at 11:02pm
i think the 6v and 12v systems use a different flywheel with a different number of teeth.
12v starter has 9 teeth...... 6v starter has 14 teeth....
why not just have your 6v starter changed to a solenoid stud... and use 12v on it ?
Edited by steve(ill) - 12 hours 12 minutes ago at 11:09pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 4 hours 7 minutes ago at 7:14am
For the B,C & CA tractor you MUST use a 14t  starter drive.
  If you are willing to change the starter drive and re-drill the starter mounting hole in the nose cone to properly  position the starter drive to the flywheel, it could be made to work.
  I would just take the CA starter to a competent rebuilder and have it made into a 12 volt unit with a stud instead of a button.
 You could just use the CA starter as is with 12 volts, however you will probably ruin the ring gear in time.
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 3 hours 54 minutes ago at 7:27am
As Paul said you might have trouble with the 6V starter using 12V on it then again i HAVE A CA with a 6V starter that I know has been cranked by a 12V battery for at least 40 years.
J&J View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote J&J Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 32 minutes ago at 8:49am
Is adding a stud to the CA starter pretty straightforward or is it more in-depth that I would need to take it to a starter repair shop?
Edited by J&J - 2 hours 30 minutes ago at 8:51am
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 44 minutes ago at 9:37am
installing the stud is not for beginners.. but if you have a BIG SOLDER IRON and you are familiar with solder techniques, it can be done at home.
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 35 minutes ago at 10:46am
I have gone through various gyrations with Model C starters.
One Model C which I owned 20+ years ago broke 3 starter drives and chewed up the ring gear on the flywheel using 12 Volts; I finally converted it to a 6 Volt alternator system before selling it.
My current Model C is running 12 Volts on the 6 Volt starter, it doesn't slam the drive in as hard as the previous one but it is still quite brisk. This starter is actually from a WD, I swapped the pinion out for the appropriate 14 tooth unit and rotated the nose cone by re-drilling the mounting holes. I also soldered a brass bolt onto the contact to convert it to a solenoid (Ford relay) system. So far so good.
Your mileage may vary Smile
This page was generated in 0.410 seconds.
