D14 Serial number
dscott View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dscott Quote  Post ReplyReply Direct Link To This Post Topic: D14 Serial number
    Posted: 16 May 2012 at 5:31pm
      Hello fellas,
             Was talkin with Brett last nite, asked him where to find the serial no. on my D14.
he explained that it should be on the left front flat of the torque tube under the air cleaner. Well as my luck goes I clean the area off and find nothing......Any ideas???
Thanks Darrell
John Sealey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John Sealey Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2012 at 6:11pm
Are you looking at the angled flat at the front of the torque tube? Its where the engine and side rails bolt to the torque tube. You may have to scrape the paint off if its been painted a few times.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2012 at 6:50pm
This picture has white tape where the number is supposed to be stamped.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2012 at 6:51pm
The engine serial number should be stamped right in front of that on the left rear flange of the block.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dscott Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2012 at 10:01pm
    Exactly where I looked. I found mine a little further towards the outside od the flange. Almost unreadable D14 3865 or 3883 as near as I can tell. The last four are very difficult to make out. Also found 210067 on the trans seam flange on the right side. And 149 4038 M  the trans and engine can be made out easily. Anyone know how to make sense of these
Edited by dscott - 17 May 2012 at 5:58pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote dscott Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2012 at 10:03pm
        WeLLLLLLLLLLLL I guess I don't have that picture upload thing figured out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2012 at 10:31pm
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2012 at 5:48am
  The  149 4038 M  would be the Engine Serial No.  149 cu.in.
Forget  what the M designation is.
Gary
BrettPhillips View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrettPhillips Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2012 at 12:15pm
Darrell:
From your picture it looks like the battery leaked at one time and pitted the casting.  I have seen that before on these tractors, but there are plenty of other clues to help figure out what year it is.  A parts manual will help quite a bit. Things like the PTO lever, hydraulic control linkage, grill, electrical system, etc. all changed at least once during D14 production, and matching them up with the parts book will help you narrow it down.  I'd guess that you are pretty close with your 38XX guess.
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2012 at 12:36pm
Battery acid  got on my ser no ,I think it starts with D14   2xxx .Dad bought it in  june of 57 so i know it is pretty earily one.
