D14 serial number location |
jtheise4
Joined: 23 Feb 2011 Location: SE Michigan Points: 144 |
Topic: D14 serial number locationPosted: 14 Mar 2011 at 2:52pm |
Can anyone please tell me where the serial number is located on a D14? Thanks.
JeffMOnt
Joined: 11 Sep 2009 Location: Ottawa, Ont Points: 129 |
Posted: 14 Mar 2011 at 2:58pm |
The serial number is located on the right side of the tractor (clutch side) by the bell housing.
Here is a link with a picture and serial listings. http://www.oktractor.com/d14data.html Edited by JeffMOnt - 14 Mar 2011 at 3:01pm |
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25247 |
Posted: 14 Mar 2011 at 6:20pm |
Hay Jeff
It's on the LEFT side on both my D-14s, I know, you guys in 'TO' get confused...hehehe
Jay
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7639 |
Posted: 14 Mar 2011 at 9:35pm |
Yes, left side (when sitting on the tractor).
onetotaltoolman
Posted: 07 May 2023 at 5:44pm |
Do the engines in the D14 tractors carry a seperate serial number? Working on the valves now. There is a different procedure (slightly) for different engine heads in the d14. The book refers to a model number, but i'm not sure if that is the serial number on the bell housing , or if there is a different number actually stamped on the engine. Anyone know?
Joined: 11 Sep 2009 Location: illinois Points: 90800 |
Posted: 07 May 2023 at 6:03pm |
the TRACTOR serial number is on the left side, bell housing flange... the ENGINE serial number should be in front of that, on the engine flange.... I believe all the D14 engines had the 149 cubic inch motor, so the serial number will be 149- xxxxxx.
