D14 pto engagement lever seal removal?
Rltool View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rltool Quote  Post ReplyReply Direct Link To This Post Topic: D14 pto engagement lever seal removal?
    Posted: 9 hours 19 minutes ago at 7:51pm
Looking for input on how to change the pto engagement lever shaft seal. The handle being welded onto the shaft poses a bit of an obstacle. Looking like I would have to remove the power director to reach where it is internally held in.
Any input would be appreciated.
Thanks!
Ray W.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 8 hours 26 minutes ago at 8:44pm
You are going to have to split it, but there is no need to remove the power director.  Drive out a solid pin that holds the lever in place.  Best to find a way to wedge the other arm in place as it is spring loaded.  Pull out the lever, replace the O ring and put back together.  Use a grade 8 bolt with a lock nut to take place of the solid pin that you removed earlier.
Also a good time to replace the transmission input shaft seal and power director O rings.
Edited by DSeries4 - 8 hours 25 minutes ago at 8:45pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 7 hours 54 minutes ago at 9:16pm
It can be done thru the side cover of power director. Not the easiest of jobs, but can be done. The detent can be tricky. HTH Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 7 hours 43 minutes ago at 9:27pm
Yea, I tried that before.  Couldn't any leverage to move the pin.  I find splitting the tractor less stressful!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 7 hours 37 minutes ago at 9:33pm
D-14 is a roll pin which removes easier.
