D14 power steering wheels
Steve(SEMN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve(SEMN) Quote  Post ReplyReply Direct Link To This Post Topic: D14 power steering wheels
    Posted: 20 Feb 2011 at 4:22pm
I have a 1958 d14 that did not have factory power steering. I added power steering to it and was wondering if  a factory power steering wheel (the one with the emblem) would fit. Are there other models that would work too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2011 at 5:02pm
Hmm... both my non-power steering D-14s have a cast A-C emblem on the wheel, held in by two screws at 9 and 3 o'clock.
Do the p-s units have a special emblem ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2011 at 5:18pm
The early steering wheels fit just like a WD45....round 7/8" diameter shaft with a solid pin driven in thru the hub to hold it. The later steering wheels with the diamond shaped cover had a threaded/splined shaft to retain the steering wheel. If you changed the shaft you could upgrade the steer wheel.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2011 at 7:59pm
The black bar grill tractors with the splined steering wheel had a diamond logo in the center that said POWER STEERING if so equiped and the A-C diamond logo with regular steering.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2011 at 11:40pm
Jay, here is the emblem.  As DrAllis and Calvin mention, the 1959 has a different steering wheel that is splined.  Earlier ones had a pin that held the wheel to the shaft.
