D-14 Power Steering Question...
JoeB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeB Quote  Post ReplyReply Direct Link To This Post Topic: D-14 Power Steering Question...
    Posted: 23 Nov 2010 at 9:04am
Good Morning, i snagged something on Allis, now the power steering line ( the smaller on off the pump) is leaking. It's a small diameter steel line that makes a Z and goes to the front bolster? My question,  is it a steel break line? Is the part available? Have not got the other end off the bolster.  Thanks, JoeB (NJ)
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2010 at 11:14am
Thats the oil return line from the pump, not a lot of pressure,   steel brake line would work.   I doubt if its available from AGCO,  maybe in a salvage yard.  good luck!
BrettPhillips View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrettPhillips Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2010 at 1:36pm
Could be either the pressure line or the bypass (relief) line.  I bought a new pressure line from AGCO about a year ago.  It was $45 or so then.  If yours isn't too badly mangled, you may be able to straighten it out and braze the leak.  Skip's idea of brake line should work well too, since the pressure line tops out at ~1000 psi, and the relief line shouldn't see anywhere near that.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2010 at 9:57pm
I also got a new line from AGCO last year for my 59 D14 with no problems.  Fits very nice and does not leak!
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2010 at 9:25am
i have some of the lines available if interested, some new, some used.
JoeB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeB Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2010 at 10:38am
Thanks Guys & Happy Thanksgiving, i ordered the part thru Sandy Lake, it'll be here next week. Cheers!
This page was generated in 0.115 seconds.
