D14 Power Director
Rick of HopeIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick of HopeIN Quote  Post ReplyReply Direct Link To This Post Topic: D14 Power Director
    Posted: 26 Jul 2024 at 1:35pm
I have rebuilt transmission on D14 to repair damaged gears.   Now it work normally without noise in reverse.   Power director seems out of adjustment and does not crisply lock in like it used to, especially the low side.   I see a shimming procedure in the manual.  Is this something that is done while working through the side cover?   Just asking for any tips.  It worked well before but I replaced bearings and gears so the things may have moved around a bit.
Eric B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2024 at 3:24pm
Yes, you can access that through the side cover to do the adjustment.
Post Options Post Options   Thanks (1) Thanks(1)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2024 at 4:03pm
It worked fine before, you did nothing to it and now it doesn't work the same ??  Shimming would be foolish and you must have the internal set-screw not tight enough.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick of HopeIN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2024 at 7:31am
Ok, will pull cover and look it over good.     Should the lever mechanism work properly when not spinning to check things out?  First time I have dug into a D series.  Owned this one for over ten years and torque director always worked fine.  Pinion shaft bearing had too much clearance and it ended up damaging pinion gear on reverse side.   That was evidently cause of noise.   Thanks for the help.
