D14 Power director |
Post Reply |
DSeries4
Orange Level Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7190 |
Posted: 13 Jan 2020 at 7:45pm |
My mechanic finally finished rebuilding the transmission in my 1959 D14 - it was only in his shop for 6 years! Now that it is as good as new, the hand clutch needs rebuilding too. The rear hub clutch (part #70228071) is what I am looking for. My AGCO dealer says they are no longer available. You can see mine has chunks missing out of the teeth. Looking for one in excellent condition or NOS. I have also heard the clutch plate assembly (Part #70232080) is available aftermarket. Does anyone have a price for these? Many thanks!
Stan R
Orange Level Access Joined: 03 Dec 2009 Location: MA Points: 943 |
jaybmiller
Orange Level Access Joined: 12 Sep 2009 Location: Greensville,Ont Points: 21318 |
wife would say you need to come down and buy #3 from me.....
Brian Jasper co. Ia
Orange Level Joined: 11 Sep 2009 Location: Prairie City Ia Points: 10508 |
All of the friction and steel separator plates are available both from Agco and aftermarket. I went through my clutch on my D17 and if I remember correctly there are 7 of each plate and the steels were about $40 each and the friction about $60 each. Then there's the roller lock plates and a center plate. To fix the clutch correctly so it stays fixed is not an inexpensive endeavor.
Off the top of my head you will also want the 6 rollers, new pin lock rings, 6 separator springs, new O rings for the power director shaft and PTO lever shaft, new transmission input shaft seal, new PTO shaft seal on the transmission side. I might be leaving something out, but this is a very good start to do a first class repair.
DSeries4
I have most of the parts I need, except for the rear hub clutch (part #70228071) - pictured above. I posted an ad in the classifieds. Please send me a PM if you have a good one. Thanks very much!
PaulB
Orange Level Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 4383 |
If you were not North of the boarder, I have a complete D15 power director I'd sell you. Unfortunately I've had nothing but problems with dealing into Canada.
If you can't make it GO... make it SHINY |
Post Reply | |
