D-14 oil pump
Speedway Steve View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Speedway Steve Quote  Post ReplyReply Direct Link To This Post Topic: D-14 oil pump
    Posted: 06 Feb 2018 at 6:41pm
Has anyone rebuilt a D-14 oil pump and find that some pumps have a ball, spring and a pin in the rotor shaft and some do not use them
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt (Jordan,MN) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2018 at 6:51pm
The ball and spring is the relief valve and was in the pump on the b,c,ca. The relief valve was moved to the front of the cam shaft on the D14 so there is no ball and spring in the pump.
Owner of Matt Scott LLC
http://www.mattscottllc.com/
Post Options Post Options   Thanks (0) Thanks(0)   Quote Speedway Steve Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2018 at 9:08pm
That makes sense. Mine does have ball, spring up front of the cam.
