D-14 oil filter/ block ?
Wes(Va) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wes(Va) Quote  Post ReplyReply Direct Link To This Post Topic: D-14 oil filter/ block ?
    Posted: 6 hours 48 minutes ago at 10:05pm
Have had this engine apart for some time.  Original tractor had a hole in the side of the block from a rod coming loose.  Found a donor D-14,  and pulled its engine apart and found good used sleeves and pistons to put in.  Im stumped on the oiling system.. the block has two ports on the right hand side like for the full flow system, but I have a bypass filter base.  Its been apart for a while and I cant remember 100% but am pretty sure this filter was on this engine.  Would it have had a plug in the lower hole and run the bypass filter?  Should I find a bypass filter setup?  There is a plunger in the front of the cam
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 6 hours 6 minutes ago at 10:47pm
I'd have to research this to give you an accurate answer. Going from memory, the early G-149's were bypass filters. The later G-149's and all G-160's are full flow filter design. The oil pumps were different. Camshaft was the same but I think the ball/spring and thrust device was different at the front of the cam.....The full flow block has different oil flow passages. Too late in the day. This has to be done right or bad things will happen. What's the s/n on the left side behind the carb ?? G-149 or G-160 ??
This page was generated in 0.111 seconds.
