D-14 manual steering leak?
rrhead(SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rrhead(SD) Quote  Post ReplyReply Direct Link To This Post Topic: D-14 manual steering leak?
    Posted: 16 Aug 2012 at 10:43am
I was wondering if the seal in this diagram is what I need to stop my D-14 manual steering from leaking? Number 26 below on the lower right. Or is there is another place for the oil to leak from? Any help would be appreciated. rrhead(SD)
2 WDs,WD45,D-14,D-17,D-19D,180,7020,6080FWA,6080 2wd, 6080 2wd(cab),8050FWA,8550,4W-305,Massey 8250. Gleaner L3, R62 &R65 Agco-Allis 1616H & 1920H, AC 720, Terra-Tiger
Steve(SEMN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve(SEMN) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2012 at 11:37am
Yes that seal could leak or the plate that has the shims. The d15 plate had a o-ring that helped seal the plate to the housing. We replaced the d14 plate with a d15 plate on my d14 for the o ring benefit.
