D14 lights?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Topic: D14 lights?
    Posted: 23 Sep 2023 at 7:57pm
Does anyone sell the original head light for the D14? I need to get a set . Thanks Tracy
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2023 at 3:29pm
Earlier 6 volt models use 4 3/4" sealed beams - have not been able to locate any.  Later models over serial number 19001 are 12 volt and use 4 1/2" sealed beams - these are still available.  I bought mine from AGCO, but Napa might be able to get them as well.
However, I was able to fit the smaller 12 lights fit into the larger buckets by wrapping electrical tape around them to increase the diameter - almost impossible to notice.  They would not work very well with 6 volts though!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2023 at 7:27pm
DSeries4, these are for my brother. It is repayment of painting my wheels. He wanted the 4 3/4 ones. Need to find some for him. New or good used. Thanks, Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2023 at 2:36pm
Good luck.  Like I said, very hard to find used.  Not available new based on my searching several years ago.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2023 at 4:26pm
Recently there are a couple guys on e-bay that are selling light + case that they SAY are 4- 3/4 inch..... that might be the OD with 4.5 inch bulbs... i dont know..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2023 at 7:19pm
Steve, I will check them out. Thanks, Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2023 at 5:47am
easy to check, see what lamp number is used !!!
sad thing is I KNOW where ONE is in garage but WHERE is it's mate ???
Chad(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chad(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2023 at 10:53am
Tracey…. Looking for the sealed beams only, or the complete buckets too?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2023 at 7:07pm
Chad, the complete light assembly. Beams and buckets. Thanks, Tracy
