D14 Lift Latches
Dave Richards (WV) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Richards (WV) Quote  Post ReplyReply Direct Link To This Post Topic: D14 Lift Latches
    Posted: 07 Mar 2011 at 3:24pm
When I got the D14 the lift latches were installed with the side bolt in the hole on the end of the lift arm.  It held, but wobbled around a lot.  I recently loosened the side bolt, pushed the latches all the way on, and tightened the bolt against the lift arm.  Seems to fit much better, BUT NOW the latches hit the fenders when all the way up.   And of course, the service book does not even address the latches.   "Wud" I do Wrong?
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2011 at 3:35pm
I have a D-14 1957 with latches . Just went and checked . Bolts are on outside  next to fender . Has never hit fender.
kffischer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kffischer Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2011 at 3:41pm
fenders/brackets bolted to wrong sides?  or wrong (too long) latch bolts?
karl f
