D14 Industrial w/ Henry Backhoe (with pictures)
elec View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote elec Quote  Post ReplyReply Direct Link To This Post Topic: D14 Industrial w/ Henry Backhoe (with pictures)
    Posted: 02 Dec 2020 at 5:44pm
My 1958 D14 industrial has the shuttle on the right-hand side.   Does anyone know if I can move it to the left-hand side and if so how to do that?  I have only ever seen them on the left-hand side.
Thanks!
Edited by elec - 04 Dec 2020 at 7:06pm
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2020 at 11:28am
Are you sure it is a Shuttle.
I seen a regular Farm D-14 at an Auction about 10 years ago.
I was interested until I seen it was a std. D-14 with a Power Director Lever on R/H side, and a regular D-14 front axle.
Had an Ind. Front End Loader and Back Hoe.
Spoke with the owner and he confirmed it was not a Shuttle.
elec View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote elec Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2020 at 7:04pm
Thank you for your reply.  Yes, I'm sure it is a shuttle, not a high-low lever/power director, and it operates as it should.  It's definitely an Industrial D14 (SN# D14 17785) because there is no PTO or internal hydraulics, and it has the reinforced heavy-duty front end.  See attached pictures.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2020 at 7:25pm
thats what i remember also... HI_LO on the right and shuttle on the left..
short movie.. at 1:30 it shows the shuttle.. Is your handle on the right side the same handle or mirror image ?
Edited by steve(ill) - 04 Dec 2020 at 7:27pm
NomoreJohnDeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NomoreJohnDeere Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2020 at 7:27pm
When you run the hoe it's on the left..........
Never seen an adjustable industrial axle before
HD3
elec View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote elec Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2020 at 7:38pm
The shuttle is on the right, it is the same handle that the rest of my AC's have for power directory on the right.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2020 at 8:40pm
I might be wrong, but I think someone might have stuffed a shuttle into a regular PD housing. IIRR, all you have to do is to flip the shaft over to change lever locations. If I'm wrong, someone will be along to correct me...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2020 at 8:53pm
Our D14 industrial has a shuttle like yours. Ours has a different front axle.
Edited by Mikez - 04 Dec 2020 at 8:56pm
elec View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote elec Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2020 at 8:57pm
@DiyDave: Thank you, hopefully you are right! I definitely will look into it.  If it makes a difference, there is also no reverse gear on the shifter, only 1st - 4th.  The reason I would like to change the shuttle to the left side is because I would like to add a hay grapple to it, with the hydraulics on the right and the shuttle on the left.
