D-14 hard starter
Austin(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Austin(WI) Quote  Post ReplyReply Direct Link To This Post Topic: D-14 hard starter
    Posted: 24 May 2010 at 1:40pm
With our D-14 that we just overhauled...once you run it for a while and use it then shut it off...It does not want to restart right after getting it all warmed up. Whats wrong? Adjusted timing and it is all where it is suppose to be. Is it a carb setting?
"Better By Design"
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2010 at 1:50pm
is it warm, or is it hot?we had a farmall 656 gas that would do the same, it could be a plugged vent on the gas cap,a weak coil,plug wires my need replacing,or maybe even vapor lock of the fuel.if we pulled started, it would fire right off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Austin(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2010 at 2:27pm
It is hot. Like i just got it out..ran it for 20 min and now it won't start. Pull starting it works great. it fires right up. it is new plug wires...coil is old..maybe needs replacing.
"Better By Design"
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2010 at 3:03pm
Is it 6 volt or 12 volt ?
Gary
Dave Richards (WV) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Richards (WV) Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2010 at 3:35pm
Austin, sounds like coil.  Pull starting should work better than starter with weak spark.  I think.    Also, make sure the centrifical advance mechanizm in the distributor is not sticking when hot.  This happened to me on a WD45 when I tried to hand crank it.  Eight years ago, bruises just went away.
D-17_Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2010 at 11:31pm
Check your valve lash adjustment.....
