D-14 Gauge available? |
rasman57
Topic: D-14 Gauge available?Posted: 22 Nov 2009 at 11:47am |
Is the Gas Gauge or parts available for my D-14? What have you done to fix yours? Appreciate your experience or info.
Chris/CT
Joined: 11 Sep 2009 Location: Niantic, Ct Points: 1939 |
Posted: 22 Nov 2009 at 5:46pm |
I have a used one available if needed.
norm [ind]
Joined: 16 Sep 2009 Location: BOURBON,IN. Points: 667 |
Posted: 22 Nov 2009 at 6:27pm |
we have new one if wanted 1-800-254-3116
john(MI)
Posted: 22 Nov 2009 at 6:47pm |
Depends on what is wrong with it. Take it out and ensure the cork is still attached and floats. That seems to be the biggest problem with them. If it is, you may just have to work it, the workings have a tendency to freeze up as well.
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7539 |
Posted: 22 Nov 2009 at 10:13pm |
Check your existing one for excessive play at the pivot point and also see if the cork slides on the rod it is attached to. Not much can be done if the pivot is worn, but the cork problem can be solved with a plastic tie strap to hold it in place. The new ones are not identical to the original (in appearance). I have found good ones at tractor wrecking yards in the past. Just got one a couple of weeks ago that is in excellent condition.
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24782 |
Posted: 23 Nov 2009 at 8:20am |
I got rid of the 'heavy cork' problem by using 1/2 a 'plastic' float from a dead Cavalier.
Unless the correct cops look into the tank nobody will ever know.
Jay
