D14 Fan and Radiator issues
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Topic: D14 Fan and Radiator issues
    Posted: 08 Mar 2017 at 8:59pm
Anyone have problems getting a new radiator to fit in a D14? I have a brand new radiator I'm trying to put in a D14 but the fan don't seen to clear the radiator. I had the stock fan on first. Now I grabbed a C fan and it still barely hits still. Are these new radiator crap?
Edited by AJ - 08 Mar 2017 at 9:00pm
Can't fix stupid
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2017 at 9:15pm
had the same thing on a 45' i took an marked it nice an cut some off with cut off wheel' an took a mower blade balance tool an balanced it before i put it on' worked good' 7 years now.
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2017 at 9:21pm
Good idea downtreader!
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2017 at 9:23pm
THANK'S LEON' Smile
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2017 at 9:38pm
Yea, I'd rather cut the fan then start cutting into the radiator supports. I had a thought to just out an electric fan on instead. Anyone ever do that?
Can't fix stupid
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2017 at 9:43pm
money ahead to trim fan' also your battery will stay up to''
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2017 at 5:04am
New radiator may be a fits all, works on none.  Also check the fan, itself, there is an adjustment on the belt, that shifts the fan to and fro, IIRR...
Dan73 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2017 at 5:12am
I was wondering about the fan being adjustable. When I got a new radiator for my d17 it didn't fit at first glance and I had to run that day so I didn't see how the mechanic I had helping me got it to fit while I was making a parts run.
But then I looked at it later nothing looked cut.
Edited by Dan73 - 09 Mar 2017 at 5:13am
ac160 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac160 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2017 at 5:40am
I put a new radiator in the 45 and had the same problem.  I trimmed the radiator instead of the fan.   No problems with it.
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2017 at 6:06am
     Only thing that shifts is 1/2 of pulley ,NOT THE FAN.
     Not very often I install aftermarket radi. that dose not require a adjustment to install.
nonetheless ,still dead.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2017 at 6:15am
OK, I'd be trimming the fan shroud.
reasons
1) only two shroud sides to trim, fan has 4 blades, so 1/2 the work
2) trimming fan blades needs to be precise( balance)
3) should has pop rivets to the 'correct cops' will know anyway
D-13#3 has a modified shroud as does the forklift..
I suppose it's really a coin toss ,maybe do what's easier and needs less bandaids ?
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2017 at 8:37am
Urge anyone seeking a radiator replacement on the smaller A-C's contact Tony w/ Tony's Tractors on this site.
Tony went through plenty clarifying which/what/how on fittings from different supply sources over the years and can typically get what you need with less headaches.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2017 at 5:58pm
OK, I stand corrected, remember I said IIRR...Wink
