D14/D15 Heads |
AJ
Topic: D14/D15 HeadsPosted: 30 Jan 2017 at 8:19pm |
Is there a difference between the head on them like a different casting number or valve size?
Can't fix stupid
Calvin Schmidt
Joined: 11 Sep 2009 Location: Ontario Can. Points: 4573 |
Posted: 30 Jan 2017 at 10:03pm |
I just put a head from a 138 cu. in. engine (early D-10/12) on a D-14 149 cu.in. engine with no problems. Don't know about the 149 to 160.
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24889 |
Posted: 31 Jan 2017 at 6:29am |
gee Calvin you could have put a D-14 head on that D-14...I got one sitting here ,looking for new home....
Jay |
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5192 |
Posted: 31 Jan 2017 at 1:48pm |
138 & 149 heads are interchangeable as mentioned. You can
put either of those heads on a 160 if you drill out the head bolt holes. 138 &149 have 7/16" bolts and the 160 has 1/2" bolts. Also the 160 head has a spot to mount the temperature sensor up front in the thermostat pot to get a true temperature reading instead of back over top of the rear exhaust valve where the reading will always be about 20-30 degrees hotter.
