D-14 clutch installation
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Topic: D-14 clutch installation
    Posted: 15 Mar 2012 at 7:46am
Ok,silly me didn't take any pictures before I removed the clutch to replace the ring gear.
Now I see that the clutch disc has different heights of the center splined 'hub'. None of the drawings or pictures I have show if it's important which side goes to the flywheel.My luck says I'll do it wrong..so can anyone help?
thanks
Jay
JeffMOnt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JeffMOnt Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2012 at 8:18am
Jay, this is what I found in my manual. "longer hub and springs of
the lined disc facing toward rear."
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2012 at 8:42am
THANKS !!
hmm..longer hub I understand...'and springs of the lined disc' ???
Post Options Post Options   Thanks (0) Thanks(0)   Quote JeffMOnt Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2012 at 9:47am
Must have been different versions of the clutch disc between factory and aftermarket. Probably had revisions along the way.
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2012 at 12:34pm
The longer part of the hub and the spring cage (if it's a spring loaded disc) will go to the pressure plate side or towards the rear of the tractor.  Rick
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2012 at 1:05pm
OK...long hub to the back.......yes, it's  an aftermarket unit (1/3rd the cost from A-C dealer !).
Man I gotta start taking pictures........
thanks
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2012 at 2:25pm
Jay, I hope it is correct. Most are not . Measure your finger height when installed on flywheel. If not correct thickness clutch is used with pressure plate machined correct ,your clutch will fail. HTH Tracy Martin
79fordblake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2012 at 4:51pm
Maybe I'm miss understanding your comment but I just did a clutch job on a D17....the book gives you the spec for the finger height and you adjust them accordingly.
