D14 3-Point lifting capacity
Butch1581 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch1581 Quote  Post ReplyReply Direct Link To This Post Topic: D14 3-Point lifting capacity
    Posted: 19 Dec 2023 at 7:25pm
Looking at getting a set of 3-point forks for my D-14 and wondering what the lifting capacity would be. Would want to move IBC totes full of green firewood. Probably 1500-2000lbs
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2023 at 9:41pm
Lifting capacity will be greatest with the hydraulic pump set at 3500 psi versus 2500 psi.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch1581 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2023 at 10:33pm
So dumb question how do I adjust the pressure? I have a 414 loader on the D14 as well with an external pump on the front
Eric B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2023 at 10:42pm
If your hydraulic pump is good you'll be amazed at the lifting power the D14 has. With my D14 without the loader, I've had too much on my forks at times, the front end comes way off the ground without even a snort. With the one that has the loader I lift my firewood processor and it's between 1300 and 1400 lbs. The center of gravity is quite far back on the processor putting high demand on the lift capacity. I would find it interesting to know at what weight it would say "no". For the size of the tractor I'm impressed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2023 at 2:00am
You haven't specified a REAR lift hitch on the lift arms (I assumed) or the FRONT lift off the loader bucket ???
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2023 at 6:45am
I have one of those snap-coupler hitches for a semi plow on my D15II and I have 1500 pounds of tractor weights on it as counterbalance for the loader instead of rim rotting fluid in the rear tires. It will lift that easily. If I had a couple more weights it would probably still lift without problems.
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2023 at 6:57am
Mine will pick up more than the front end will hold down
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2023 at 7:01am
made this 23 years ago, forklift forks fit it, have hauled 3000# logs on it, you  NEED weight up front though ! IBC toes are easy to carry,BTDT too .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch1581 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2023 at 7:17am
That’s pretty awesome. I thought about building something similar since we already have the clamp on forks. Otherwise I was just gonna buy this: With the loader on the front we will be able to pick up something for counterweight I was just worried about the 3 point being strong enough to lift the weight with it being put away from the pick point a bit. IMG_6194.png
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2023 at 8:04am
gee for $250 that's a pretty good deal .
Since I get steel for free and my time is 'free', I've always liked to 'bodge' instead of ,yuck, buy..
Whichever way you go, be sure the load can't hit the rear tires !!! BTDT..it becomes 'interesting' !!
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2023 at 5:20pm
Butch, I do exactly what you're suggesting with my D17.  I have a homemade 3-point kit, and a face mount that has standard forklift forks on it (yes, they slide from side to side, which you'll eventually want).
I use this setup for moving pallets and IBC totes all the time.
I'm certain that the smaller D will be just as willing to lift... but beware... an IBC tote full of green wood hanging on the forks will give your lower radiator a very clear view of the sky.  I usually have to hang a bunch of assorted ballast on the nose of my 17 in order to keep the wheels close enough to the ground to provide a little direction.
It is wise to lift the tote JUST ENOUGH to clear the ground, just in case you wind up nosing up, it will cease climbing when the forks touch the ground.
I've lifted over 3000lbs with my D17's forks on 3-point... just enough to get it off the ground, then steer with brakes, it'll move LOTS.  Now, it won't lift really high, but if you put a loading-berm in your yard, you can back a pickup up to it, and then bring the forks over to set a tote in a pickup.  I have three forklifts, and the one thing that the Allis CAN do, that the forklifts simply cannot... is traverse soft ground with that load.
Sliding forks is a good thing... if you can save the Vevor coin and just fab your own mounting face for a pair of used forks, do it.
