D-14 3 point rotary tiller opinions
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Topic: D-14 3 point rotary tiller opinions
    Posted: 28 Jun 2010 at 6:38am
Hi guys. Finally decided to get a 5' wide rotary tiller for one of my D-14s and of course need to convert it to snap-coupler.I've downloaded pictures 3 or 4 different 'adapters'.
The tiller would be permanently attached(everything else is S-C !). I'm thinking of making my own adapter to save money,so I'm looking for any 'words of wisdom' and/or pictures if you've already done what I'm about to do.
I know I'll need a oneway clutch gizmo....
Also ,wondered about getting a 4' wide unit leaving the tractor at 5' to create 'foot paths'.
All this for 6 veggie gardens, less than 1 acre each around the 'neighbourhood'.
Thanks for any help
Jay
Tony.Or View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony.Or Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2010 at 11:38am
Jay !!  I would  use a drawbar mounted  hitch , much better  sway control than the old wishbone  ac  came up with.  you would have   your  3 point & still  be able to  pull from drawbar.    Tony
Burgie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burgie Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2010 at 12:49pm
Jay, Like Tony says. I have a 3pt conv. from Tony on a D15 series II and use a 6` tiller. I just love it. That way I have 3pt and snap coupler available and your traction booster will work with your 3pt. You still have your factory draw bar. Works great!!
"Burgie"
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2010 at 1:22pm
I disagree.  I would use the wishbone (quick) hitch.  Since you have all SC equipment it's not that hard to mount the hitch conversion to the impliment.  You can make a attachment point on the cross-tube to mount the toplink.  Then you can drop the tiller, and hitch together.  I use the drawbar mounted on D15, and have used both on everything from WD's to D17's.  For general purpose, I do like the drawbar mounted better.  But then you would have to drop the hitch, and the drawbar seperate from the tiller.  3 steps instead of 1.
If you would like, feel free to call my toll free number listed in my sig.
I would be happy to let you know what my experience has been with them on my AC's. JImD
Owner of OKtractor.com PM for an instant response on parts. Open M-F 9-6 Central.
We have new and used parts. 877-378-6543
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2010 at 2:29pm
As always great suggestions and a vasriety of thoughts.
I have to add I've  NEVER used either drawbar( 2 D-14s, 1 regular, 1 heavy duty),both collect dust in the corner...
I'm liking the idea of the adapter/tiller as 'one piece' as the tiller will be the only 3point implement.
Would appreciate more thoughts and a picture or two of a tiller setup,
thanks
Jay
