D-14/15 WD tire question
Joe7077 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe7077 Quote  Post ReplyReply Direct Link To This Post Topic: D-14/15 WD tire question
    Posted: 10 Feb 2012 at 8:43am
Hey all,
I have a question about the bolt spacing on the rear axel of my D14.  I assume the bolt spacing is the same as a D15 but does it match the WD series or D17 series?  I'd like to buy some newer tires for my D14 and I see WD Rear tires all the time, I was wondering if they would just bolt right on or if the bolt spacing wouldn't match.  Also, while we're on it, do the snap coupler spring packs and bell housings match?  Could they be swapped between a D14/15, WD or a D17?  My D14 snap coupler spring pack housing was broke sometime in the past and welded back together.  I'm also missing the release lever, there's a jerry rigged chain there now that kinda works but i'm trying to get all the parts put back to what they should be.  Has anyone ever gone through and compared a WD series and a D14/15 series to see what could be swapped between the two?  I see WD's fairly often and was wondering if picking up a donor for my D14 would make sense.  My D14 was used pretty hard and just cobbled back together to keep it running.  I'm slowly putting it back to the condition it should be in and just lurking here has been a huge help, thanks for any advice you all could give.
HagerAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2012 at 9:06am
The 28 inch WD or D-17 wheels will bolt right up to a D-14.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2012 at 9:14am
Also 26" combine rims/tires fit as well ! Try local yards ,especially after a 'combine derby'. I got a pair,50% tread, for $100.
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2012 at 10:09am
The wheels will bolt up, but if you try to spin them all the way in they will hit the fenders. You can get spacers to set them out, but they are hard to find and rather expensive. Make sure you use rail stops!
Here is what the factory 28" option included.
Edited by Eldon (WA) - 10 Feb 2012 at 10:24am
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe7077 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2012 at 12:57pm
Thanks for the info and the picture.  Anyone know about the snap coupler assemblies matching across the product lines?
