D14/15 front axle |
im4racin
Joined: 12 Jun 2017 Location: Garrison ND Points: 1122 |
Topic: D14/15 front axlePosted: 04 Mar 2026 at 9:11pm |
Is there any difference in the two? Exactly the same or minor differences?
Posted: 22 hours 30 minutes ago at 7:24am |
There are several different front axles, but it seems the part numbers are all the same between the D14 and D15. I do know that the casting under the radiator/front support is different, as the D-15 is wider.
im4racin
Posted: 20 hours 1 minutes ago at 9:53am |
Only talking about the weldment and spindle stuff. Have a D15s2 that had a loader, axle has been welded on alot!
Edited by im4racin - 20 hours 1 minutes ago at 9:53am |
Leadoff
Posted: 14 hours 27 minutes ago at 3:27pm |
im4racin
D14 one bolt thru the slide/frame at either side next to spindle - D15 S2 two bolts, both have second bolt/capscrew either side towards middle of axle in the slotted section of the outer slide frame My D15 S2 has two bolts next to the spindle each side. Pic search on Internet shows some D14 with two bolts, some with one, perhaps special factory order or upgrade over the years using donor axle from a D15 S2????? Early D17 were same, one bolt next to spindle. Later D17 two bolts Perhaps an easy way to identify differences Not sure if second bolt really improved performance
1963 D17D Series III. 1965 D15 Series II. 1965 D17 Series IV. 1975 185. 1978 716H. 1979 716H. 1965 780 Harvester/1R&DC. 1957 Model 73 SC 4 Furrow Plow
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7626 |
Posted: 14 hours 11 minutes ago at 3:43pm |
Only early D14s have one bolt on each side of the spindle. Later models after serial 19001 have 2 bolts on each side like the D15. The one difference between the late D14 and D15 is the rear wishbone hanger. D14 uses a flat piece of metal. D15 has a jog in it.
im4racin
Posted: 11 hours 50 minutes ago at 6:04pm |
Ok thanks! I will see what I can locate
