D-12 sers.III tranmission service
Marlyn nwia View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Marlyn nwia Quote  Post ReplyReply Direct Link To This Post Topic: D-12 sers.III tranmission service
    Posted: 25 Feb 2010 at 12:24pm
Where do you fill the trans. with oil?  Are the two trans. connected? (2 speed high/low) and the standard trans.  What is the "steel ball bearing" in the plug on the right side of the High/Low trans. good for?  I know I need an operator's manual for said tractor!  Thanks for any help.  Marlyn
BradinNC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BradinNC Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2010 at 6:37pm
The ball bearing in the side is the detent for the high low shifter handle.
You put the fluid in the same place for the range as you do the rest of the hydraulic oil.
This page was generated in 0.305 seconds.
