D12 lift cylinder packing
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Topic: D12 lift cylinder packing
    Posted: 12 Apr 2019 at 7:56am
My cylinders leak pretty good and I was going to replace the packing.
Mine is a Series II (Post 3500 serial) with the Gland nut
Parts supplier has a Kit but it does not indicate if it is for both cylinders or not. Kit is pretty pricey so I was wondering if any of you had redone these before. My 190 lift cylinders were pretty cheap to do
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2019 at 8:09am
Charlie, when I did mine for my WD45 I bought them from Sandy Lake.  I believe it was just for one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2019 at 8:24am
Yep, I called them. Kit is 3 times the cost of my 190 kit.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2019 at 8:27am
Minparr is $95 for their kit!
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2019 at 9:38am
Picture for reference
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2019 at 5:52pm
The last cylinder I did up with new V packing and new guide bushing, cost me $8 for the packing from Motion Industries and there were 2 more v seals than I needed.
 You have to measure the bore and the rod and they will match you up with what you need. Depth of gland and thickness of the nut wouldn't hurt to have written down.
 881 Auto Motion Way, Harrisonburg, VA 22801
Edited by CTuckerNWIL - 13 Apr 2019 at 5:52pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2019 at 5:33am
I didn't think about them, they are local to me. I get bearings there.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2019 at 7:50am
When I worked repairing machine tools, about 90% of our bearings and seals came from Motion Ind.
