D-10 |
Post Reply |
timg
Bronze Level Joined: 01 Mar 2010 Location: NC Points: 3 |
Posted: 13 May 2010 at 8:34pm |
What do yall think a 1963 D-10 with a busted block is worth? The rest of the tractor is in fair shape. I have a (i think) 1959 D-10 and thought that I might pick up the other tractor for parts. I can only see a few changes on the 1963 from the 1959. Will most of the parts work on my 1959 model?
Thanks
timg
DREAM
Orange Level Joined: 06 Jan 2010 Location: Elberton,GA Points: 1828 |
Not an expert on the D-series, but wouldn't there be a series change from 1959 to 1963? Maybe series 2 to series 3? Somebody else will help, just bumping it up.
Walter(MO)
Bronze Level Joined: 26 Dec 2009 Location: Warrenton, MO Points: 127 |
The Series II D 10 will have independent P.T.O. and a different hydralic pump. Also the engine will be more cubic inches having the same H.P. as a D14. The Series I will have the same H.P. as a CA with a CA hydralic pump and P.T.O.
GregLawlerMinn
Orange Level Joined: 11 Sep 2009 Location: Lawler, Mn Points: 1226 |
Thinking out loud, not knowing the extent of the cracked block, the condition of the tractor, and knowing the relative rareness of the D10 (approx 2500 made); it may be worth the effort to rehab it. Have seen pretty badly cracked blocks fixed up with plastic steel. If the block is too far gone to be fixed up, a donor 149 or 160 engine will bolt right in. Not for sure, however, but would suspect that the 125 would also bolt in without much of a fuss. If it were closer and it is complete, I would offer $1500 for it and consider it to be a candidate for a rehab project. |
Currently have: 1 D14 and a D15S2. With new owners: 2Bs,9CAs,1WD,2 D12s,5D14s,3D15S2s, 2D17SIVs,D17D,1D19D;1 Unstyled WC |
Post Reply | |
