D10 Series III Voltage Regulator Mounting
Blake_AllisMan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blake_AllisMan Quote  Post ReplyReply Direct Link To This Post Topic: D10 Series III Voltage Regulator Mounting
    Posted: 09 Sep 2024 at 12:02pm
Looking for some help with mounting my voltage regulator for a D10 series III. I want to put it in the correct location. From the old pictures I viewed, it looks like it mounts below the generator. Is there a special bracket that I need to mount it? Would someone be willing to share some pictures of their D10 series III and voltage regulator? Thanks for the help!
1941 C
1952 IB
1947 C
1955 WD45 SFW
1956 WD45 Diesel
1977 5020 4WD Serial Number 1
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2024 at 12:17pm
You are correct, there is a bracket the bolt on with the generator bracket. I don't have a picture handy at the moment. I had bent up a few of them to have on hand a while back, I don't know if I have any left or not.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blake_AllisMan Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2024 at 12:36pm
Thanks for confirming. If anyone has the bracket to sell or some better pictures of it that would be awesome. When I got my tractor, it was missing. Thanks.
1941 C
1952 IB
1947 C
1955 WD45 SFW
1956 WD45 Diesel
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blake_AllisMan Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2024 at 3:20pm
Alright so I did a little digging and I think I found the bracket in the AGCO parts book. The part number is 70241730. Does anyone have one I could buy or copy for my project? Thanks in advance.
1941 C
1952 IB
1947 C
1955 WD45 SFW
1956 WD45 Diesel
dfwallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2024 at 3:46pm
I know you've already got the part.  I bought a regulator that fits on the CA generator (79004807) exactly in the place of the cutout.  It works great although it is larger and does limit the belt adjustment range of motion slightly.  I resolved that by changing the belt length.  So far, so good.
1952 CA13092
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blake_AllisMan Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2024 at 7:47am
I would be willing to mount it on the generator but unfortunately it doesn't have any holes on the generator to mount a regulator. Therefore I would like to find the original bracket and make it correct. Not restoring the tractor but planning on taking it on some rides and tractor shows.
1941 C
1952 IB
1947 C
1955 WD45 SFW
1956 WD45 Diesel
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2024 at 9:35am
Sorry, the replacement generator I checked before posting did have the holes.  I didn't check carefully enough for the OEM.
1952 CA13092
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blake_AllisMan Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2024 at 1:44pm
Still looking for this bracket. Thanks
1941 C
1952 IB
1947 C
1955 WD45 SFW
1956 WD45 Diesel
This page was generated in 0.097 seconds.
