D10 Series 3 traction booster
Chris View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris Quote  Post ReplyReply Direct Link To This Post Topic: D10 Series 3 traction booster
    Posted: 08 Nov 2020 at 7:56pm
Any ideas what I can check, it's not working.All linkages are hooked up.
Thanks,
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2020 at 8:53pm
Hooked up is one thing.  froze up is another.  I don't know exactly how they are supposed to work, but on my 10 and 12, there are some linkages under the valve bank, beside the right fender, that when jiggled vigorously, while cursing loudly, seem to have the desired effect of getting them to work...Wink
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2020 at 5:42am
The valve body on the load linkage gets stuck. It moves up and down with the load as it senses the position of the linkage. I have had to grab the end of the shaft and move it back and forth to get it to work.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2020 at 9:11am
Negate what I said, that was for the series 2
I will have to look at my 3 when I get home to see how that is set up
Charlie
This page was generated in 0.199 seconds.
