D-10 series 3 pilot bearing? pilot bushing ? |
Post Reply |
tractorboy
Silver Level Joined: 03 Oct 2009 Location: southern Va Points: 453 |
Posted: 29 Jun 2024 at 11:35am |
Bout ready to put son's engine back in. According to everything I read , supposed to have a pilot bearing. This one has a bushing that slides onto the larger shaft. I've ordered a bearing, & a bushing and neither will work. The bearing is too big to fit into the flywheel & the bushing is too small, only fits on the live PTO shaft. any help appreciated! keith so. va.
SteveM C/IL
Orange Level Access Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8089 |
Some one said that series had live hyd and shaft was splined to flywheel
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 78809 |
skip down about 10 posts to Garys comment...
tractorboy
Yes that small shaft is splined into the flywheel, there's still a bushing that fits into the flywheel & slides onto the larger shaft. That size bushing doesn't match up with anything in DJ"s or Steiner's or anything I can find on fleabay. Guess I'll clean up the old one & reuse. keith so.va.
i think that was the conclusion... that the bushing that IS AVAIALBE is for the Series 1... not yours..... seems odd that nobody sells the NEW one.
Gary
Orange Level Access Joined: 13 Sep 2009 Location: Peterborough,On Points: 5230 |
Part 'Description' The Ser.I part is titled BUSHING Clutch Shaft The Ser.II and III is titled BEARING ASSY. clutch The Ser.II and III Clutch Disc Assy. is different P/N than Ser.I G ................................................................... Dug up some old pictures I took when I replaced the Ring Gear in my D-12 Ser.III It appears there is a 'Bushing' in a rearward facing nose of the Flywheel. It would seem this Bushing / Bearing would support the end of the hollow Tube that is splined in to the Clutch Disc and powers the Transmission. Edited by Gary - 30 Jun 2024 at 8:14am |
Mikez
Orange Level Access Joined: 16 Jan 2013 Location: Usa Points: 8215 |
236056 bushing is still available
8 digit number would be 70236056 - bushing.
Post Reply | |
