D10 ring gear
Ranse View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ranse Quote  Post ReplyReply Direct Link To This Post Topic: D10 ring gear
    Posted: 18 Jul 2022 at 10:38pm
About 50 percent of the time I try to start the tractor the starter will grind.  The only way to get it to stop is to crawl under the tractor with a flat screwdriver and give the flywheel a couple of turns through the hole in the bottom of the bell housing.  Then it starts right up.  I figure it's a bad spot on the ring gear.  What else could it be?  I thought the ring gear was replaced a few years ago when I had the engine rebuilt.  Could it have striped this soon?  The tractor isn't used very much.  Anyway, what's the best way to tell for sure without splitting the tractor?  Are these aftermarket ring gears like from DJ's good, or should I try to get one elsewhere?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2022 at 4:44am
pull the starter, stick your phone camera (on video) in the hole, and rotate  the engine, by jacking up a rear wheel, put tractor in 4th gear.  plugs out of the motor to make rotation easier.  There is a problem that shows up sometimes, if the wrong starter drive (# of teeth) is used, it can wear the ring gear prematurely...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2022 at 6:30am
Converting a 6 volt system to 12 volts is most likely the cause of ruining a ring gear so quick as well as the mix of a 12 volt ring gear to a 6 volt starter gear or vice versa, as Dave mentioned.
  If your tractor has been converted to 12volts from 6 volts, get your starter properly rebuilt with a 12 volt armature and field coils, or you'll be right back to where you are now in no time. regardless of where you get the ring gear from. Everybody sells aftermarket parts from the same supplier. Also get yourself a proper starter drive to go with the ring gear. A worn gear against a new gear is asking for trouble.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ranse Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2022 at 7:32am
The tractor has always been a 12 volt system since new, so that shouldn't be the problem.  I've had the starter rebuilt in the recent past.  I'm pretty sure they put a new drive on it.  I couldn't tell you if it has the right number of teeth or not.  I don't know how many teeth the drive is supposed to have.  I know DJ's sells two different ring gears for a D10.  I don't know which one I need.  I figure if I pull mine I will count the teeth before I order one.  I will pull the starter and look inside.  I would think if the starter in grinding when I pull it I shouldn't have to rotate the engine.  The stripped spot should be right there shouldn't it?  BTW has anyone ever removed a ring gear and rotated it and reused it?  That way the stripped spot will be somewhere else and not in the spot where the engine always stops.
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2022 at 7:53am
Match ring gear to starter #
nonetheless ,still dead.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2022 at 8:00am
Ranse... your right, the engine normally stops in one of two different positions.. Those two spots will show 90% of the total wear.  You should see that thru the starter hole.. Thats why you can rotate the crank about 4-5 teeth and it works OK.  You can remove the ring and turn it 90 degrees and reinstall, assuming the wear is all isolated to two spots.. Make sure you get a 12v starter gear as mentioned, not the 6v.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2022 at 8:34am
As far as flipping it goes,one edge has chamfered teeth and the other does not. Be ahead to reinstall 90 degrees off like Steve says. Heat makes them move easier but don't use so much you take the tempur out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ranse Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2022 at 12:39pm
Well, I removed the starter and inspected the ring gear.  There's no doubt about it, there's definitely a bad spot there.  I assume the teeth at the other stopping point are in better condition.  This would explain why the tractor only fails to start half of the time.  In theory, I believe that rotating the ring gear 90 degrees would last just as long as a new one.  You would be using the unused teeth.  But with that said, I'm not sure if that's the way I will go.  I will make that decision later.  After looking at the starter gear again I'm not sure if it was replaced or not.  The starter gear has more chamfer than the ring gear, but it may have some wear too.  It could be a combination of both gears.  This is going to make me sound like a moron, but I thought a gear was a gear.  What's the difference between a 6v gear and a 12v, and how do you tell the difference?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2022 at 12:49pm
the 6 volt gear has 10 teeth.............. 12v has 9 teeth.
Edited by steve(ill) - 19 Jul 2022 at 12:54pm
