D-10 or D-12 Series III?
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Topic: D-10 or D-12 Series III?
    Posted: 12 Sep 2010 at 8:47am
This little tractor is on display (along with some other brand X tractors) at our local vegetable stand.
I stopped to look at it but none of the owners was around to answer any questions.
And..........I didn't have the presence of mind to look at the serial number........duh!!!!!
Anyway, I fell in love with this little beauty immediately!!
I was really impressed with the ruggedness of the 3PH system.
Without the decal or the ser. number, is there a way to determine whether its
a D-10 or D-12?
wood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wood Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2010 at 10:13am
It look like a D12 to me.
realolman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote realolman Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2010 at 10:29am
Ain't that prettier than a new set of snow tires....I don't know and I am no expert.... but a guy told me the d10 did not have spin out hubs.
Edited by realolman - 12 Sep 2010 at 10:30am
RMD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RMD Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2010 at 11:05am
Spin-out rims were standard on the D-12; optional on the D-10.
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2010 at 11:24am
D-12
Charlie
caRon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote caRon Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2010 at 11:32am
I like the big tires on the back. What are those 13's?
CA Tractor
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2010 at 2:55pm
Looks like a D12 Series III, serial 9001 +, has 14.9x24 rear and heavier 15 inch front(car rims) which were an option,  optional tach, spin outs- optional, lights-?.
 Check the lift links, look to be adjusted all the way out which may indicate the threads are  stripped.
Rick of HopeIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick of HopeIN Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2010 at 3:07pm
I have been advised to look over the 3 point real close if you are buying.  Some parts seem less than rugged compared to the lift force available from them cylinders.
Brian Ahart View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Ahart Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2010 at 3:15pm
Yes, it appears to be a D12 III.  Notice the arched flat stock piece that runs from the top of the front axle back to the wishbone-shaped axle support/brace.  A picture of the other side should reveal the dual-link D12 III steering linkage as opposed to the single link on a D10 III.
Notice that it has the coveted Series III throttle lever cover which is missing on most units (including mine).  I have been tempted to have one reproduced, but am holding out for an original.
A-C Weight ID reference and other goodies at brianahart.net
Post Options Post Options   Thanks (0) Thanks(0)   Quote realolman Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2010 at 4:44pm
I wish it were mine.  10 or 12.
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2010 at 5:50pm
Looks like a 12 to me
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2010 at 7:23pm
If you look at the middle ( #2 posted), look at the right side between the lift link and tire, the axle has two bosses protruding out where rear mounted SC implements were mounted; mower, cultivator, etc.  The D10 has only one of these.
Absolutely a D12, other items in pics won't change anything.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2010 at 9:35pm
Well Joe, the fact that the final drive housing part numbers are different between the D-10 and D-12 seems to confirm what you are saying.
The next time I'm in the area, I will make a point of writing down the serial number to identify the year of manufacture.
Thanks for the input from all of you.
