D10 manifold |
Ranse ![]() Orange Level ![]() ![]() Joined: 11 Mar 2016 Location: Tennessee Points: 775 |
![]() ![]() ![]() ![]() ![]() Posted: 16 Mar 2018 at 9:16pm |
I need to drill and tap the holes that holds the muffler on. I think it's probably pointless to try to get the broken bolts out. How deep are the holes, or do they go all the way through? I think they would easier to tap if I drilled them all the way through, although this is probably not correct. I'll be putting bolts back in them so there shouldn't be a leaking problem.
I can probably do this with the manifold on the tractor, but I think I'm going to remove it. It has a new gasket, I just wondered if I could re-use it? Thanks Ranse. |
DiyDave ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54213 |
Exhaust gasket is probably toast, anyway, they get brittle after just a few hours of running. I'd just get a sharp bit, and drill it still on the motor...
GregLawlerMinn ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Lawler, Mn Points: 1226 |
All that I have seen went into the manifold bore and were tapped.
Currently have: 1 D14 and a D15S2. With new owners: 2Bs,9CAs,1WD,2 D12s,5D14s,3D15S2s, 2D17SIVs,D17D,1D19D;1 Unstyled WC |
