D-10 III...... Industiral ???
tractorboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorboy Quote  Post ReplyReply Direct Link To This Post Topic: D-10 III...... Industiral ???
    Posted: 27 Mar 2018 at 5:37pm
The d-10 I bought at auction a couple weeks ago may be an industrial.  Amp gauge stays pegged, so I pulled side covers off & looks to be some hints of factory yellow!  Maybe thats why the grille & seat look wrong for a 66 model. Also has a push button start, is that correct?{never seen one on a d 10}. I pulled the front rockshaft off, maybe this wkend take some pics, it will be for sale, not the tractor just the front cultivator assembly, brackets, & cyl. Serial no. is 9416
Larry in NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry in NC Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2018 at 5:47pm
The I400 had a different front axle and the serial number you listed is correct for a Series III D10.  The differences you listed are just things that were not replaced with original parts.
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2018 at 6:50pm
sent PM
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2018 at 8:13am
The D-10 series III has a 12 volt electric system with push button starter.
Dusty
RMD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RMD Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2018 at 11:28am
The primer that AC used was yellow. Most times when you see yellow paint on a D-series, it is just the primer showing through.
