D10 D12 fuel line? |
Post Reply |
Tracy Martin TN
Orange Level Access Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10665 |
Posted: 11 Oct 2010 at 9:49pm |
What type of fittings were on original fuel lines? Were they flare,inverted flare or compression ? Thanks Tracy Martin
Dusty MI
Orange Level Joined: 13 Sep 2009 Location: Charlotte, Mi Points: 5058 |
Tracy, it appears they are inverted flare.
How are you doing on the molds for shock absorbers for the shaft coupling? Dusty
Tracy Martin TN
Dusty, Almost half way thru process. Will try to send your NOS back this week. Thanks for your help with this project. My fuel line has a compression fitting. Was wondering what were on most out there. I am sure it could have been replaced. Thanks Tracy Martin
Dusty MI
My parts book shows a 90* fitting at the carburetor and a straight fitting at the sediment bowl, 1/8" pipe to 1/8" tubing. It doesn't say they are they are inverted flare but that's what they are. An old friend always referred to them as navy flares.
Dusty
Chalmersbob
Orange Level Joined: 11 Sep 2009 Location: Pennsylvania Points: 2122 |
They are inverrted flares as on steel brake lines.
All of the gas lines were steel. Brake line is very bendable when it is new. Bob
Steve in NJ
Orange Level Access Joined: 12 Sep 2009 Location: Andover, NJ Points: 11899 |
Not sure on a D10-12 machine, but all the original ones I've had on my tractors were compression type fittings. Coarse, they're gravity fed, so not much psi on the fittings. Lots of vibration though. When I make the upgrade fuel lines I sell, I then go to inverted flare with the correct fittings to make the kit...
Tracy Martin TN
Steve, That was what was on mine. I just ain't a fan of compression fittings either. Thanks Tracy Martin
Post Reply | |
