D10/12 Power Steering Leak
easygoin4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote easygoin4 Quote  Post ReplyReply Direct Link To This Post Topic: D10/12 Power Steering Leak
    Posted: 25 Nov 2009 at 9:57am
I am new to tractors and looking for some advise prior to opening her up.  I have developed a leak what appears to be coming from the bottom of (2) of the 4 line nuts that go to pump under the tank.  I dried her off then ran awhile and looks like its coming from between the nut and the case?  The 7/8" nuts are tight- first thing I tried.  Appears that they are original and may have never been off.  Any ideas as to what is under the nut? O-ring or seal?  Or is it a flared line?  I will be looking at it this weekend and did not want to be too surprised.  Hopefully easy fix.  Also- the (2) that are leaking are on the rt. side if it matters.... Thanks in advance - Chris
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2009 at 10:02am
you might have a fatigue crack in the pipe right at the edge of the flare, and you will have to remove to see
This page was generated in 0.035 seconds.
