D10/12 Loader
Jim-Ohio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim-Ohio Quote  Post ReplyReply Direct Link To This Post Topic: D10/12 Loader
    Posted: 21 Jan 2011 at 2:39pm
'61D17, '51WD, '51CA, '41C, '49C, Woods 5'&6'Mower, 6'Blade, CA-Plow, CA-Cultivator, 3-Btm snap-coupler plow, 4-row planter, WD 4-row cultivator, 80R mower,#7 mower,B/C mower
AC WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2011 at 2:44pm
it may fit but it's fully hydraulic. Your CA is meant for a trip bucket loader. You would also need to retro fit the brackets.
German Shepherd dad
1957 Allis Chalmers WD45
#WD234847
1951 Allis Chalmers WD
#WD88193
John (MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (MO) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2011 at 7:23pm
There is only one hose to each cylinder, I believe those cylinders are one way.  Should fit with a little work on the mounts.  I doubt you will find mounting holes that line up on a CA, so it will require some shop work.
RMD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RMD Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2011 at 10:41am
I'm pretty sure that you would have to fabricate brackets for the mounts on the side of the engine, probably mounting to the same points as CA cultivators.  Also the seat on the CA is a lot farther back to the rear of the tractor, so you would have to re-locate the controls so you can reach them from the operator's seat.
This page was generated in 0.039 seconds.
