D series tach drive gears
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Topic: D series tach drive gears
    Posted: 03 Feb 2010 at 8:54am
Thanks to my new found friend Austin (WI) I have a D-19 tach drive gear coming. And I would like to suggest Virginia Vettes as a source. Super nice people and $25 delivered to your door. Just google the name to get the web site and contact info.
Austin(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Austin(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2010 at 12:36pm
Lets hope that your main shaft isnt roached in the distirubtor...as mine is..i have to get a new main shaft because the gear teeth on there are rounded. grrrrr keeps getting better better an. lol
"Better By Design"
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2010 at 2:40pm
Never fear Austin, LOL. When I was looking over the 'Vette sites for a deal on the gear I see that the main shaft for the chebby distrib is available too for not too bad money as is the bronze bearing/ guide that the short shaft rides in. I dont have one in front of me but going from the pic it looks to be usable to easily make a D-19 shaft out of.  I had to re-bush my distributer and my mainshaft gear is good. I have a lathe and mill and can make the vette shaft work  if they are not available from AGCO or they want to rape you for it. Let me know if youneed some help with it.
Josh(NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh(NE) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2010 at 12:28am
can anyone confirm if that is the same drive gear used on a 301 in a 190xt gas. Thanks
Allis Express
'65 190XT, 37 B, '72 170, '83 8030, and the IH 560 was a mistake
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2010 at 3:00am
D19 gear & cross shaft ....4054849  main shaft incuding weight plate....4514746
190    "    "    "        "    ....4056704     "      "        "           "         "  ....4056701
190 XT lpgas                ....--------                                                ....4058902
  LP gas  distributer had several different pieces inside weight plates and main shaft , the weights and springs
 D19 gas             Delco dis. # 1112615
 190 & XT ...        Delco dis. # 1112653
 190XT propane...    "      "   # 1112667
Hope this helps. I have 190 gas that needs that gear & cross shaft too. Don't remember if dist gear is good or not.
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2010 at 9:02am
After further review. I ordered one of these "corvette" gears and found out they are not the same as the D19 drive gear, the "corvette" one is 0.030" smaller in diameter on the gear and doesn't mesh with the dist. drive gear very well. it might work at first but probably not for long.
Matt
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2010 at 11:37am
As much as I hate to be the bearer of bad news, usually its the main shaft gear that wears the drive gear out. Did quite a few of the 1112615 Distrib's and both were wiped out. I would suggest pulling the Distributor and disassembling the unit and pull the main shaft out for a good inspection. You'll probably find its also toast. Better than ruining a new drive gear and having to buy another drive gear. Its sorta' like having a wiped out rear end pinion gear and not replacing the ring gear also.... Just my 2 cents...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Austin(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2010 at 12:54pm
Did you try it Matt? Mine needle was very jumpy when it was running so i stopped and took it out and noticed that the distributor gear was pretty roached..and was missing teeth.
Edited by Austin(WI) - 05 Feb 2010 at 12:55pm
"Better By Design"
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2010 at 2:00pm
Steve,
As you probably saw in my prior popst it doesnt look like it would take much to adapt the long shaft out of the 'vette either, at least for a guy who knows his way around a lathe and mill.
norm [ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2010 at 1:51pm
  doc's equipment had a good 190 distributor an gear
