D series silver paint and others
JVON View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JVON Quote  Post ReplyReply Direct Link To This Post Topic: D series silver paint and others
    Posted: 09 Jul 2017 at 11:11pm
So I am almost ready to start putting some Persian orange 1 to make my 57' D17 correct for the era. I have been researching pictures to make sure I am as accurate as possible. There are three colors that I am not sure on. The silver used for the air cleaner, black for the starter and generator and silver for the rims. I realize the rims were originally galvanized but what would be close? I have 95% of everything primed and still a few more details to work out. I checked the knowledge base for paint codes and don't see those listed. Any ideas or recommendations?
Jay
lowell66dart View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell66dart Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2017 at 7:01am
Case IH makes a silver paint that works well.
AC 6080 (8030,7060,200,175,D-17HC, 6040,160,6140 all gone) Farmall 1066 & 656 Hi-Clear (for sale), White 2-62 High Clearance, JD 4255 Hi Clear.
Macon Rounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2017 at 10:34am
I use Rustoleum silver. Flows GREAT and covers unbelievable...
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2017 at 10:36am
I've never sprayed it myself, but someone on here posted that Ford Argent Silver is what they use.
grinder220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2017 at 11:55am
I've been using rust-oleum aluminum on all my rims. Looks really good in my opinion.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2017 at 12:12pm
Does the Rustoleum paint hold up over the years ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2017 at 12:20pm
This is on my G705 moline but it gives you an idea of what it looks like.
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2017 at 12:21pm
only time I've ever had to touch up is if the rim was rusty from calcium chloride to begin with otherwise its held up really good.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2017 at 12:52pm
I meant to say Rustoleum aluminum "color" also.... i have sprayed it and brushed it on. I like spray results better....If you sand blast and prime before application your results will be good.. like all paint jobs, preperation will determine end result more than the paint you use. I like light gray primer because it gives a lighter finish color than dark primers......
JVON View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JVON Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2017 at 5:10pm
I haven't been able to sandblast anything (no access to a sand blaster) but have been using wire wheels and 3M paint and rust remover wheels.  It has been more time consuming but I feel the results are just as good if not better.  I have been Case gray primer on everything and from the look of the finish on the primer I think the final paint will look fantastic.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2017 at 5:15pm
Aluminum colored paint works well for the wheels and air cleaner.  For the starter and generator, I use gloss black - might be too shiny for some, so a semi gloss would also be good.
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2017 at 7:38pm
I used Rustoleum cold galvanize spray on my D14 rims.  Sorta dark and a flat finish but it looks fine to me.  I didn't restore it, I just repaint anything I have to repair or replace.
JVON View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JVON Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2017 at 10:14pm
I can get my hands on case silver or aluminum. Either would look good. What are your thoughts on either color? I think the aluminum would be slightly brighter. Maybe look closer to galvanized steel?
