D motor grader
Don N View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don N Quote  Post ReplyReply Direct Link To This Post Topic: D motor grader
    Posted: 30 Oct 2011 at 11:52am
I have a model D motor grader, model WD266394GA, sn D3919, have taken the motor out to rebuild and noticed the flywheel has several cracks, have read that cracks are not a big deal.  Just resurface and put back in.  Thoughts and/or ideas are appreciated.  Is this a 1939?
DonBC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonBC Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2011 at 1:02pm
That would be a 1954 model. The W 226 engine is the same as used in the WD45 farm tractor. According to the farm equipment section comments, cracks in the flywheel are not uncommon. If you need another flywheel there should be lots of WD45 or D17 parts tractors that can be a donor.
Don
